Re: Bead and Cove
Posted by Russell on Nov 8, 2004
The bead and cove:
Gives you more glue contact surface.
"Holds" the strips in place when glue is wet.
AND as you stated everything is twisted so if you used flat strips you would need to fit (i.e., sand, cut, trim, plane) each and every piece for its entire length. The bead and cove is semi self adjusting (less fitting).
P.S. Epoxy....not carpenters glue
In Response to: Bead and Cove by Mac on Nov 8, 2004
- I have done it both ways by MWagar on Nov 8, 2004
Re: Strip Build Education by Mac on Nov 9, 2004
- Re: Strip Build Education by Ron on Nov 9, 2004
- what do you wear? by Peter on Nov 9, 2004
- Re: what do you wear? by Mac on Nov 9, 2004
- Re: what do you wear? by Peter on Nov 10, 2004
- Keeping Feet Dry by Mac on Nov 11, 2004
- Re: what do you wear? by LeeL on Nov 10, 2004
- GREAT SITE! by Mac on Nov 11, 2004
