I'm about to start a WD 14 but I think i'd like the cockpit to be a little smaller maybe about the size of the WD 12 cockpit. Has anyone done that modification???
RE: Cockpit WD 14
I'm building from plans not a kit....so it should be almost a non issue right?
Planning on cutting the deck pieces this Sat...wish me luck.....
RE: Cockpit WD 14
» Submitted by John, CLC - Tue, 3/4/14 » 12:15 PM
It's plausible. Because of the jigsaw-puzzle assembly of the Wood Duck 14, it's not as easy to change cockpit sizes as it is on, say, a Chesapeake-series kayak. You'd need a new "cockpit apron" with your smaller cockpit opening in it. The apron itself would remain the same size to fit the other deck parts.
