Q on the order of things.
Posted by mullman on Jun 3, 2005
My pram is progressing well. I plan on leaving the inside bright and painting the lapstrake panels on the outside.
Just to make sure I understand since I want to finish the inside to a high standard. Before applying any unthickened epoxy to the inside I should sand from 80, and work up to 220 until everything is ultra smooth, correct?
Then build up several thin coats of unthickened epoxy, sanding 220 in between?
I really want my inside to look like this!
my goal
- Re: Q on the order of thi by Steve Miller on Jun 3, 2005
two fast coats of epoxy Q by mullman on Jun 6, 2005
- Re: two fast coats of epo by Mike D on Jun 6, 2005
