Re: two fast coats of epo
Posted by Mike D on Jun 6, 2005
Tacky is good. If you are able to put the second coat on while the first coat is still green (set up -tacky but not gooy -, but not completely cured) the coats have a "chemical bond" thing going for them. Otherwise, you need to sand to give the surface a tooth so the next coat can get a mechanical bond.
If at all possible recoat while the first coat is still green.
Happy building, MD
In Response to: two fast coats of epoxy Q by mullman on Jun 6, 2005
