Re: uncured epoxy - help!
Posted by Terry Mcadams on Oct 21, 2004
Yeah, Katherine, try a carbide scraper, if you have one (if you don't, about $20 at the home center and WELL worth it). Then heat. Then sanding, into the cloth if you have to (you can add a cloth patch later).
Do try avoid the mistake I once made of absent-mindedly mixing the vinegar with the olive oil before using it to disolve the epoxy.
terry
In Response to: Re: uncured epoxy - help! by FrankP on Oct 20, 2004
- Re: uncured epoxy - help! by Mark Camp on Oct 22, 2004
- Re: uncured epoxy - help! by Terry Mcadams on Oct 22, 2004
