Re: starved scarfs?
Posted by CLC on Feb 8, 2005
If the glue has cured, and you were even reasonably thorough in brushing on the epoxy, there is seldom any danger of a weak joint. It's a surprisingly forgiving step.
Be careful moving the panels around at this stage. Once everything is 'glassed, the strength of that joint (and everything else) is multiplied many times.
I've had far more failures as a result of over-sanding the scarfs----"wasp-waisting" the thickness of the panel at the scarf----than I have from glue issues.
In Response to: starved scarfs? by Vic F on Feb 7, 2005
- Re: starved scarfs? by Gafrick on Feb 8, 2005
Don't Worry - Be Happy by Kurt Maurer on Feb 8, 2005
- Re: Don't Worry - Be Happ by Mark Camp on Feb 9, 2005
- by on
Re: starved scarfs? by CLC on Feb 8, 2005
- Re: starved scarfs? by Doug Judd on Feb 8, 2005
- Re: starved scarfs? by Dave Bokros on Feb 13, 2005
- Re: starved scarfs? by Laszlo on Feb 8, 2005
