I have successfully used Titebond II for years. To build the stripped deck on my new Woodduck Hybrid 10, I purchased a bottle of Titebond III which is labeled as waterproof. After a half hour of glueing strips, I was pleased with the rapid bonding and less yellow color of the glue. Then I tried to wash the crusty glue off my hands. It took 10 minutes of scrubbing with abrasive hand cleaner and the green abrasive side of a Scotchbrite heavy duty scrubbing sponge to get the glue off my finger skin and nails. The label says, "water clean up." In reality cleanup must take place within 5-10 minutes of using the Titebond III. Now I always put on nitrile gloves before picking up the Titebond III bottle.
RE: Titebond III caution
Hi Grumpy
Sorry my message about Titebond III was not clear to you. I have worked with epoxy for years and always wear gloves, eye protection and long sleeves. I have also worked with Titebond II for years and never needed gloves because Titebond II cleans up with soap and water. My message was for new users of Titebond III.
» Submitted by Grumpy - Fri, 2/7/20 » 9:50 PM
So, how do you do with epoxy?
