Re: epoxy/glass separatio
Posted by Howard on Jun 20, 2005
these little bubbles should be opened up....use a sharp knife to cut away the "white/dry" glass to open it up until you are to the properly wetted out glass...then sand lightly.
if the divots are small...i take a drop or two of unthickened epoxy...drop it into the divot and then place a piece of scotch tape over it to hold it in position/make it flat.
after it cures...pop the tape off and hit it with a sanding block to fair it in.
hs
In Response to: epoxy/glass separation by Phillip on Jun 20, 2005
