Re: Varnish MC 16.5
Posted by Steve Miller on Jun 2, 2005
Yep, Penetrol in the varnish (2 or 3 ounces per qt) and a good foam roller. On a cool day you may not even need to tip. If you do then tip with a foam brush using just the weight of the brush, no more. The roller will put the varnish on smoother and faster than a brush so all the tipping does is pop any bubbles. Note that the foam rollers seem to have a grain to them. One direction will leave more bubbles than the other. Check on each roller and then remember which way to hold it as you work.
If you have spots that looked like you missed well then you probably did miss. No harm.
In Response to: Re: Varnish MC 16.5 by J.Schott on Jun 2, 2005
