also- make sure that
Posted by Charlie Jones on Oct 9, 2004
you have a nice flat surface under that feather edge that you can plane into a tiny bit without hurting your plane edge. As long as the lower surface of the ply is held tight against that table surface you'll have MUCH less tearout. Plus when you get really close, reset your plane (or get another) to a very fine shaving and work the final couple of strokes that way, cutting the very edge with the grain. Personally I do the very last little bit with a redwood float normally used for concrete work. I have one that is trimmed to just the size of a piece of sandpaper and I wrap the paper around it. Gives a very flat finish to the scarfed surfaces. I can shoot you a pic of it today at the shop and post it this evening.
And if it DOES tear out, it's really no big deal. If it's a HUGE tearout, slide the ply forward a half inch and recut it. No biggie.
In Response to: Re: cutting the first sca by Kurt Maurer on Oct 9, 2004
- Re: also- make sure that by Steve Miller on Oct 9, 2004
how many at one time by Ray on Oct 9, 2004
- Re: how many at one time by Kurt Maurer on Oct 9, 2004
