Re: Here is a reason:
Posted by Chris on May 5, 2004
You could alwasy install those little drain plugs, (they are really cheap and I think clc sells them. that way, you can realease the air and drain out the water. Also, if you don't want to deal with the hatches on the deck, you could install those small flush bulkhead openings. big enough to pack a lunch in.
cj
In Response to: Hatches by peter shadbolt on May 4, 2004
- Re: Here is a reason: by RogerJ on May 6, 2004
- Re: Internal hatches by Sailboy on May 6, 2004
Re: Internal hatches by Dave Houser on May 6, 2004
- Re: Internal hatches by Mac on May 6, 2004
- Re: Internal hatches by RogerJ on May 7, 2004
- Re: Internal hatches by Sailboy on May 7, 2004
- Re: Anchor out... by Sailboy on May 8, 2004
