Re: deck glass
Posted by mike on Apr 27, 2004
Yeah, I had an endpour leak on me and what a freakin' mess. I jammed a window weight into where it was leaking and when the epoxy cured, that was fun to pull out. Nothing like compouding one error with another. :)
On the second kayak I built, I cut out two v shaped wedges which I then epoxied into teh bow and stern at an oblique angle to that I had enough to drill the grab rope hole. Once that cured, I filled with epoxy and no leakage occured.
mike
In Response to: Re: deck glass by Doug Judd on Apr 27, 2004
