Re: warped hatch
Posted by George K on Apr 7, 2005
It's a simple solution. Make sure all four clamps are the same. Simply clamp 'em on, lay the hatch bottom side down on your workbench (or any other flat surface)and press on it until all the clamps are seated firmly on the bench. This will remove the twist. Leave it there until the epoxy cures. A dry run is a good idea to make sure you understand the process.
In Response to: warped hatch by ray on Apr 7, 2005
