Re: Sanding tips
Posted by terry on Feb 22, 2005
I like the sanding pads for the edge work. I do go over the edges (and the entire boat, for that matter) with the scraper a few times until allhigh spots and rough areas are gone. Then I use power sand pretty much like Steve says, then I use the 3M sponges on the edges - very carefully, because even these sponges can easily sand the epoxy off a sharp edge.
Fairing boards for edges, Mac?
In Response to: Re: Sanding tips by Karl on Feb 22, 2005
