Re: Fillets
Posted by Tony Calvert on Nov 28, 2004
Hi Parke,
It sounds like you need to add a bit more woodflour to your epoxy so that it was a little thicker. The epoxy tends to thin a little as it generates heat so I usually err on the thick side for any fillets on a vertical surface.
Fixing it is easy if you can get an angle grinder or dremel in the area (be very careful), otherwise good old fashioned elbow grease and coarse sandpaper.
Cheers Tony
In Response to: Fillets by Parke on Nov 28, 2004
Fall Kit Sale 2016
