Re: Mark- aren't you in T
Posted by RogerJ on Nov 29, 2004
Plastic syringes made specifically for use with epoxy are available from West Systems, I buy them at West Marine (no relation) any place that stocks WS supplies can get them. The long tapered tube is built in, can be trimmed for a larger opening, is unlikely to be used for administering anything IV. I clean them with vinegar and reuse them a couple of times. Eventually the rubber seal gets too hard to seal well, but epoxy is thick enough to work in them. RogerJ
In Response to: Mark- aren't you in Texas by Charlie Jones on Nov 29, 2004
