Re: Fillets
Posted by Craig Robinson on Nov 29, 2004
A thicker mix as mentioned. Also, after you have wetout the area that you are filleting with unthickened epoxy, let it soak in for a bit and then wipe off excess epoxy. This will help keep the mixture at a suitable consistency as there is a tendency for the epoxy to pool. Especially at the keel join.
In Response to: Re: Fillets by jahrome on Nov 28, 2004
- Re: Fillets by Mark Camp on Nov 29, 2004
