Re: Does this make sense?
Posted by terry on Oct 7, 2005
Sanding to 220 should be fine. I wouldn't go any finer before another epoxy coat.
You probably already know this but one of the tricks to getting very thin coats of epoxy is to mix very small batches - may 2 oz. max. This is even more important in hot weather. As the epoxy kicks off, it becomes increasingly dificult to roll it on fast and very thin without using a squeegee.
Good luck. Wish I had time to start another boat this winter, but I gotta restore some rotten gingerbread on my always-threatening-to-fall-down-because-I'm-too-lazy-to-maintain-it-Victorian-house.
terry
In Response to: Does this make sense? by Mulepilot on Oct 6, 2005
- Re: Does this make sense? by Kosta on Oct 19, 2005
- Re: Does this make sense? by Kurt Maurer on Oct 19, 2005
