Narrowing
Posted by Howard on Jun 4, 2005
J.
Glad you figured out photo-bucket. Looks very interesting. I had been toying with a minimum weight 17lt for a while as well...but still in the notes stage.
can you tell us more about how you made her 2 inches narrower? did you modify the bottom or side panel from the plans? or did you simply let the hull fold closer together?
did you consider reducing the height of the side panels at all? (lower the freeboard).
and just to confirm...is the bottom panels 4mm or is the whole boat in 3mm?
thanx
hs
In Response to: Re: please send/post pict by J.Schott on Jun 3, 2005
