Re: screwing deck beams
Posted by RogerJ on Jun 28, 2004
Mischa, my canoe is not a CLC design but, I used screws to hold the deck beams in position where needed. When the epoxy hardened I drilled the hole clean, soaked it with raw epoxy (not thickened at all ) then filled it with epoxy, wood flour and silica mix. Is it as hard as a bronze screw(?) I dunno, but I am betting it stays put. RogerJ
In Response to: Re: screwing deck beams by Doug Judd on Jun 27, 2004
