Re: Once again - H20 read
Posted by Kurt Maurer on Jun 21, 2004
A simple answer from an even simpler mind. Hell no. Take it out and enjoy it all you like, although I will say it's most convenient to leave the sanding 'til *after* you return to the shop.
As long as all the wood is protected (read: waterproofed) with epoxy, you're good to go. The rest is for appearance only. Yes, even the UV protection, as long as you don't let it go TOO far...
Cheers, Kurt
In Response to: Once again - H20 ready? by Homer on Jun 21, 2004
- Re: Once again - H20 read by Laszlo on Jun 22, 2004
