Re: "Lift off speed"?
Posted by Mark Camp on Apr 28, 2004
That helps, but my boat will not have enough power to reach that speed, even with an electric trolling motor.
However, I read somewhere that, if you build a tall enough tower in your backyard, and climb to the top of it, you will have enough speed, due to the rotation of the earth and the mechanical advantage due to the height, that you can go into orbit by simply setting your kayak down in mid-air, climbing in, and pushing off.
In Response to: Re: "Lift off speed"? by Chris H on Apr 28, 2004
- Re: "Lift off speed"? by Chris H on Apr 29, 2004
