Re: How long did it take?
Posted by Chris on Apr 21, 2004
So there you have it, It truly is dependent on how much time you can spend on it, (can you work a bit on it every night?) How much time you spend thinking it out, and trying to figure out the most efficient method, (A lot of it ties into working neatly to minimise sanding, tape off what you can, and wipe up any excess squeeze out you can reach, much easier to wipe up soft epoxy than sand off rock hard epoxy), how much of a perfectionist you are, and how limited you are by your work environment, (do you have a heated garage or are you building under a tarp in your driveway.) Doesn't matter whether you take 2 1/2 weeks or 2 1/2 years, just do it, you'll love it.
In Response to: How long did it take? by Jay E. Morris on Apr 21, 2004
- Re: How long did it take? by Jay E. Morris on Apr 22, 2004
