Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Re: Sticky Varnish
Posted by Bob Santore on Mar 31, 2008
Check to see if your varish will cure ok on a clean surface (not epoxy coated). If the problem isn't the varnish, it might be amine blush. If it is blush, and even if you scrubbed the surface, a couple of days curing might not have been adequate for all the blush to form prior to varnishing.
In Response to: Sticky Varnish by Kevin Sio on Mar 31, 2008
- Re: Sticky Varnish by Steve Miller on Apr 1, 2008
