Removing epoxy from sheer
Posted by Hoffmann on Mar 20, 2007
When fiberglassing the hull, excess epoxy ran down onto the sheer clamps and above the lip of the side panels. Thus, planing the sheer clamp with a block plane is impossible due to the dried epoxy (bumps, runs). I have a dremel tool, belt sander, rotary sander, and block plane. What is the most effective way to remove the glue and proceed with planing the sheer clamps?
