Re: Removing epoxy from s
Posted by Laszlo on Mar 22, 2007
Camper,
You are absolutely correct when it comes to fully cured epoxy. However, if it's been less than 24 hours or so since application you'd only need a touchup sharpening, if that.
My rule of thumb, literally, is that if I can dent the epoxy with my thumbnail I'll plane it. Otherwise I'll use the shinto rasp or sander.
In Response to: Re: Removing epoxy from s by Camper on Mar 22, 2007
