Re: sanding primer
Posted by Howard on Jun 13, 2005
mike,
when working with the primer...you should sand almost all of it off. its purpose is to fill minor pin-holes and other small imperfections..not to to take the place of good hull prep.
the other reason you want almost all of it off is that it is not a good backing behind paint that is exposed to water. Primer is relatively soft...and if you scratch the paint...the primer layer will absorb water and flake.
So again...when you have done it right...you will only see the primer in the smallest of holes and imperfections...and clear epoxy for 95% plus of the remainder.
hs
In Response to: sanding primer by mike aguado on Jun 13, 2005
- Re: sanding primer by Mac on Jun 14, 2005
Re: sanding primer by AoftheN on Jun 14, 2005
- fillets by Howard on Jun 14, 2005
- Guide Coat by Rand on Jun 14, 2005
- Re: Guide Coat by Mac on Jun 14, 2005
- Re: sanding primer by mike aguado on Jun 15, 2005
