Posted by Howard on Jun 14, 2005
primer is too soft and is not meant to fill these types of voids.
if you are painting the boat...just fill these spots in with thickened epoxy...the easiest to sand thickener would be some type of fairing compound. but you can also use wood flour...or cabosil...but just be sure to just fill in the voids...and clean up any excess. you don't want to make it too much of a pain to sand.
In Response to: Re: sanding primer by AoftheN on Jun 14, 2005
