Re: help !!!!!!!!!!!!!!!
Posted by Howard on Jun 4, 2005
start by wiping up as much of it as you can.
any fibreglass that was wet out with this unmixed epoxy should be discarded.
we want to get back to whatever the surface was prior to doing this.
was this over bare wood or over an already existing epoxy layer?
i will leave it to others to recommend the appropriate way to removed the residue of what cannot be wiped off. i expect that they will recommend either denatured alcohol, vinegar or some other chemical to get rid of the last remnants.
don't panic...it can be fixed with no ill effects...other than a little more time.
hs
In Response to: help !!!!!!!!!!!!!!! by Tammy on Jun 4, 2005
