Re: Fiberglassing How To
Posted by Chris Taylor on May 10, 2005
For glassing the hull and deck, the one thing I would stress is to work with small batches of fresh epoxy - especially if it is warm. I work with a 1/2 cup or so at a time. This way the stuff stays very fluid and wets the glass easily. All the pumping and mixing gets tedious, but it is worth it. As soon as the epoxy starts to "kick" it doesn't soak in as well and you may end up with dry weave, floating glass and bumps before you know what is happening. I pour it on a little at a time and work it in gently with a semi-flexible plastic squegee that I have sanded the edge with 400 grit to ensure there are no barbs. Try to keep your strokes moving from the keel to the shear. Start at the centre and work towards the bow and stern. For the first coat, just try to wet out the glass (weave should be wet, but not filled out), being careful to work out excess that can "float" the glass. Work slowly and methodically. Give yourself enough uninterupted time to finish the coat. Remember - small batches. Maybe get someone to mix small batches continually as you work.
In Response to: Fiberglassing How To Help by Eric on May 9, 2005
- Re: Fiberglassing How To by Eric on May 10, 2005
Good luck, Eric. by Robert N Pruden on May 11, 2005
- How did it go, Eric? by Robert N Pruden on May 11, 2005
- Re: How did it go, Eric? by Eric on May 11, 2005
- Printemps a Quebec by Mac on May 11, 2005
- sounds like New England by Karl on May 12, 2005
- Same here, Eric by Robert N Pruden on May 12, 2005
- cracked scarfe joint by Al on Mar 10, 2007
- Re: cracked scarfe joint by CLC on Mar 10, 2007
Re: cracked scarfe joint by Alan Speakman on Mar 11, 2007
- Re: cracked scarfe joint by Al on Mar 11, 2007
