cracked scarfe joint
Posted by Al on Mar 10, 2007
just noticed crack through middle layer of my 4mm okoume on the scarfe line also about 1/2 an inch in glue joint on stern bottom panel on my first kayak a 17lt it's not stitched together yet so do i cut it off and fit a slightly longer piece in as the new scarfe will start where the old one ended (cracked) also the outer veneers haven't cracked only middle core.
In Response to: Re: Fiberglassing How To by Chris Taylor on May 10, 2005
- Re: cracked scarfe joint by CLC on Mar 10, 2007
- Re: cracked scarfe joint by Alan Speakman on Mar 11, 2007
- Re: cracked scarfe joint by Al on Mar 11, 2007
