Re: cracked scarfe joint
Posted by CLC on Mar 10, 2007
It's a little hard to visualize what you're describing, but if you're worried about the integrity of your scarf joints, back them up with a strip of fiberglass tape on the inside surface of the panel. If the scarf joint really is compromised, that will add enough strength to allow you to assemble the hull without worries.
In Response to: cracked scarfe joint by Al on Mar 10, 2007
