Re: Hip foam + back band?
Posted by Tim M on Nov 1, 2004
I thought about doing the foam all the way to hull, but ran into the same problem. Luckily the CH16LT comes with pre-cut wood for mounting the foam. The straps for the back band pass right behind them. (notice the sketch on the left. If you don't have the pre-cut pieces, you could easily fashion some out of scrap or even some thin ply from Home Depot.
Another option might be to cut a notch in the foam to accomodate the strap.
In Response to: Hip foam + back band????? by Homer on Oct 31, 2004
- Re: Hip foam + back band? by LeeG on Nov 1, 2004
Re: Hip foam + back band? by Homer on Nov 1, 2004
- Re: Hip foam + back band? by LeeL on Nov 1, 2004
