Re: Hip foam + back band?
Posted by LeeL on Nov 1, 2004
I used the wood blocks but have not put any foam on them yet. I also screwed the straps to the shear clamp per the kit instructions. There are a couple of reasons for going this route, if a rudder is later installed the cables will need to be routed behind the wood braces, and the space between the braces and the side of the hull is a good storage area. I store a bildge pump and a paddle float there.
In Response to: Re: Hip foam + back band? by LeeG on Nov 1, 2004
Fall Kit Sale 2016
