Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Eastport Pram - adding sail rig
It may be a year or more after completing the rowing version of the E.P. before I can afford (time/$) the sail rig. Has anyone added the rig after the fact? Was it as simple as advertised? Any drawbacks to waiting? Thanks again, Dave
1 reply:
RE: Eastport Pram - adding sail rig
» Submitted by Eric N - Fri, October 23 » 9:57 AM
I'm in 'home stretch' of finishing the 'rowing version' now, and I too plan to add the sail rig at a later time. Yes, it does appear to be as easy as it's advertised. There's a hole in the forward seat (thwart) where the mast will pass through, and you also have to build a small mast step on the floor of the boat (under the hole in the fwd thrwart) to seat the bottom of the mast. You also have to cut a hole in the middle thrwart for the daggerboard and it's trunk - all of which takes place during the building of the 'rowing version'.
