How do you finish the edges of a paddle: cut the glass square at the edge of the wood. taper the wood and extend the glass a short distance from the wood, you can't wrap the glassm around the edge because that is too sharpe of curve?
Well if you're not going to use bone edges, I've seen commercially-made paddles that use epoxy edges. I copied that for the tapered back edge of a rudder and it works really well. If/when it does chip, it's easy to fix. The process is like putting a big fat fillet on the edge of your paddle and sanding it to shape. It works for any application where you need a tough edge that's easy to maintain. Here's how I did it:
1. Leave the wooden edges square.
2. At the edge of the paddle blade, run a 2" wide piece of clear plastic packing tape along the entire length of the edge. About 1/2" of the tape width should be firmly attached to the bottom face; the rest just hangs out in the air. NOTE - if you're using a splintery wood like red cedar, removing the tape WILL pull up splinters. In that case the wood (at least under the tape) should be coated with epoxy and allowed to cure before the tape is applied. That will prevent splinters.
3. Put a stiff mixture of epoxy and woodflour in the angle where the tape and edge meet. The bead should be as high as the edge and twice as wide as the edge is high.
4. Fold the tape up along the bead onto the front face. This will trap the epoxy/woodflour putty against the edge. Attach the tape firmly to the front face. Watch out for air bubbles.
5. When the epoxy cures (I'd give it a couple of days), take off the tape and you will have a rough epoxy edge on your paddle. It will be ready for sanding to its final shape. If any air bubbles have formed, they can be filled with more putty and sanded.
Note that depending on the brand of the tape, you may be able to squeeze it into an approximation of the final shape and eliminate some sanding.
RE: paddle
» Submitted by Laszlo - Sat, 3/9/24 » 8:20 AM
Have fun,
