Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Drip rings on Greenland style paddle
Has anyone added drip rings to a one piece homemade Greenland style paddle? If so, where did you get them or did you make them?
RE: Drip rings on Greenland style paddle
OK attempt 2, there was supposed to be a picture after the first paragraph above.
One great advantage iof the Greenland paddle is that you can slide your hands from one end to the other,see http://superiorkayaks.com/superiorkayaks2009_004.htm Drip rings would retard this motion. SEEYA Jack
I recently bought one of Eric Schade's gorgeous Greenland paddles and quickly learned that they work very differently from modern paddles. They seem to work best with short low angle strokes. And the blades are narrower and not scooped, so they don't tend to pick up water that requires drip rings. I also learned, later in the first day that I used it, that these paddles use different sets of muscles than the modern ones do. -Wes
» Submitted by David.Donaldson - Wed, July 22 » 12:40 PM
At my Paddle Canada Level 1 Course I attended this past weekend, I got to try a greenland paddle (now on the aganda after my C18), that was one of my questions. The answer back was sure, rope. I was thinking keeping with the style:
I guess you could try finding a rubber ring, heat it up in a nice warm bath of water and stretch it on...
