Wet sanding varnishing prior to the final coat
Wood Duck Double:
Right now I'm working on the bottom of the hulll before finishing the deck.
Currently on third coat of varnish. Waiting for it to dry prior to the fourth coat. I wait 24 hrs between coats, dry sand with fine 3m pad, tack cloth, then wipe down with a cloth lightly dampened with denatured alcohol, and wait about two hours prior to applying the next coat of varnish.
After the 4th coat ..... my plan is to wet sand using 400 grit. Looking for input on this final sanding prior to adding the fifth and final coat to the hull. Regards......
