First build - Misc questions on pre-finishing Sectional Shearwarter Sport
I'm carefully, but optimistically, venturing into the finishing stages of my kit Sectional Shearwater Sport build. I'm planning on a painted hull and varnished deck. This is my first build and I have read, bookmarked and valued many great threads in this forum regarding finishing, but I do still have some novice questions. Frankly, I have a lot of questions, but I'm trying to focus on the topics I've been most foggy about.
Initial Level of Sanding. I have a fully glassed boat with the weave showing mostly everywhere. Initial epoxy coats are fully cured (applied many weeks ago). I want to start out with a good surface here for fill coats but also assume I should go pretty light on prep sanding so as not to nick the actual glass. The edges where one layer of glass ends over another are especially ugly and I know I should spend some good time feathering these with course sandpaper while also knocking down any egregious drips with a scraper. However, I'm not sure where to go from there. I assume a light ROS sanding everywhere (maybe 120 grit) to ensure mechanical bond for next layers? I don't see any signs of blush, but honestly I'm not sure I even know how to check for it. So perhaps a good all-surface cleaning is in order as well?
Structural Considerations for Miocro Balloons Use. I've read many posts on prepping for paint and am fully convinced that miocro balloons are the way to go when prepping the hull. It seems some folks fill the weave normally, and just use micro balloons for final faring layer, while others use them from the start when filling the weave. I'm leaning toward the latter as it seems like the fastest and lightest way to get a smooth surface ready for paint. However, my understanding is that fill coats are structural but epoxy thickened with micro balloons is not meant for any structural application. Is the idea here to simply ramp-up the amount of micro balloon filler across a couple coats such that the initial layer is still reasonably hard (structural, but still lighter than unthickened epoxy) and the final coat is very soft (not structural but very sandable)? If so, could the first fill layer still go on with a roller?
When to do Water Trials. It seems like best practice to do some test paddles before getting too far along into finishing work to catch and address any leaks (especially important for the Sectional). Technically I suppose I could do that now since everything has one layer of epoxy, but is it best to wait until right before paint/varnish stage since fill coats may improve water tightness?
So several questions here :) but I think if I can deepen my understanding on these topics, my next few weeks of work will go much much smoother (pun intended).
5 replies:
RE: First build - Misc questions on pre-finishing Sectional Shearwarter Sport
Thanks Hspira, yes, that does help.
A couple takeaways:
- It's probably best for me to stick to at least one more "normal" (unthickened) fill coat on the hull before exploring any micro balloons. Once that's done it'll also be a good milestone for the water test ahead of any faring.
- I need to get some scotchbrite pads. That's a tool I have yet to make use of.
Thanks again.
Seems to me your over thinking things .roll on epoxy until you don't see the glass weave and take your time sanding.unless your having to cover up mistakes that should be enough. If you want you could use a high build primer on the painted areas but even that has some drawbacks
Just a few thoughts on microballoons.
First, concerning structural uses of microballoons. When you see that they are not meant for structural use, that means things like thickeners for glue joints between structural members. Filling the weave is finish, not structure. Once the glass fibers are properly saturated, they are structurally complete. Filling the weave is a cosmetic and protective process, not a structural one. That's why it's perfectly safe, from a structural point of view, to leave the glass in interior areas unfilled.
As far as hardness, microballoon/epoxy mix cures much harder than paint, high-build primers, etc. so in the event of a scratch it will not be what fails first. And scratches are all the you need to be worried about. The glassed wood is what handles impacts, twisting, bending, pulling, etc.
And if you are not sure about taking my word for it, look to the world of home-built, hand-built composite aircraft. Standard practice for scratch builds is to do a glass lay-up with an epoxy content as close as possible to 60% epoxy/40% glass (which will always leave the weave unfilled) and to fill the weave with fairing compound. If that's good enough for a 600 lb, 200 mph plane that has to sit out on runways, fly through bad weather and endure bumpy landings, it's surely more than enough for a 40 lb boat that speeds along at 7 mph and lives indoors or under a cover. Even cartopping speeds are not a problem.
Filling the weave with unthickened epoxy is a heavy, expensive and unnecessary option unless you are finishing the boat with varnish. It adds no strength beyond what the glass and wood already provide and only marginally more abrasion protection.
Second, fully-cured balloon/epoxy mix is watertight. The balloons are dust speck sized, so even a very thick mix has lots of epoxy in it, plenty to seal micro-cracks. The balloons are small enough to fit into micro-cracks. It'll survive a sea trial just fine.
Finally, I like to do sea trials between the fairing and painting stage. That way I get to test the final shape of the hull but without having to do all the finish sanding.
My 2 cents,
Thanks Laszlo for the additional feedback on the structural considerations of the fill coats. That’s very interesting. As greg27 noted I may be overthinking things here but I really do enjoy learning not just “how” to do this build, but also “why” various steps are done the way they are done (or could be done differently).
For now I’m building up 2 fill coats on the hull before switching to micro balloons, but in a future build I think I’ll try making the transition earlier. Minimizing weight will be a fun new challenge for a future build, even if it's just a few ounces here and there.
» Submitted by hspira - Sun, 3/20/22 » 10:54 PM
Hi rjacobs,
Thought I would try to address your questions as asked.
On the initial level of sanding. If you still have a lot of weave showing, I would lightly abraid the surface with a green scotchbrite pad and wipe down with denatured alcohol to remove any dust… and then add a couple more fill coats. For me, after the initial wet out, I usually have three weave filling coats. I work carefully so my fill coats are rolled on then I use a plastic squeegee to smooth the surface (knock down any bubbles and move the epoxy into the low spots). That is usually enough to allow for sanding the surface to a smooth finish without going into the weave. As for blush, if you are using MAS medium epoxy ..these are non-blushing epoxies and you should not have to worry about blush.
On the structural consideration for micro balloon use…..there are a lot of opinions on this but i limit my use of micro balloons to address final fairing issues (like a depression that needs to be filled). I don’t substitute it for filling the weave as I agree with the hardness issues you mention in your question. Also, in my view, you don’t get a surface that is much lighter or easier to sand unless your microballoons are applied like a paste (e.g., bondo consistency) which is how I use it…..so i want a very good water-proof layer in place before any 'bondo' consisency micro-balloons are applied.
When to do water Trials….i would have all my fill coats in place prior to any water trials. With only wet out glass, there is still the probability of small micro-openings (e.g. bubbles) that can allow water to get behind the epoxy into the wood. After a couple of filler coats, that risk is pretty much off the table. So I agree with your intuition and have seen it in practice that one coat is not a very reliable seal against water intrusion.
hope that was helpful.
