Sand inside hull between epoxy coats?
Working on my WD12 and I've completed the fillets & taping on the interior hull and deck. Plans now call for a second coat of epoxy. Do I sand between these coats, or is that overkill?
1 reply:
RE: Sand inside hull between epoxy coats?
» Submitted by wookmaster - Tue, 1/18/22 » 4:40 PM
I followed this after making the mistake of sanding between coats for no reason and it worked well
https://www.clcboats.com/shoptips/epoxy_and_fiberglass/epoxy_faq.html
