Shearwater Sectional / Re assembly following sectioning
Dear Forum,
Have just sawn a perfectly good kayak into 3 pieces, and now have to figure how to put it together again.
The instructions are a bit vague.....
If I read between the lines and make liberal use of my Ouiji Board, it should go something like this:
-Redrill the holes as instructed
-Seal the freshly exposed wood surrounding the holes with unfilled epoxy
-Let the epoxy cure
-Redrill the holes again
-Insert the bolts,
-Pray
Can anyone confirm?
Kirkham
1 reply:
RE: Shearwater Sectional / Re assembly following sectioning
» Submitted by Birch2 - Thu, 10/28/21 » 9:38 PM
I just reread my manual and if you follow the instructions, you will be fine. No Ouiji board required! .
