Built lovely CLC 17' touring kayak in the Annapolis shop, several years ago. It has skid strips fore and aft, flush hatches, also adjustable foot pegs. So pretty that I have used it half a dozen times in fresh water. $1300 or Best Offer for a Good Home. 412-480-8940 for pictures and further details
RE: Lovely 17" LT Kayak
Carey,
The official paddler weight range is given in the kayak comparison chart as 160 - 220 lbs, but the description page says 140 - 220 lbs. Either way, he is definitely in the fit range while you are either in it or just below. Just below is the right way to miss. It can be fixed with ballast, which is much easier than amputation.
For that matter, the builder doesn't give the boat weight. if the build ended up on the heavy side, there could be no problem at all for you.
17LTs are routinely cartopped, so you're OK there, too.
Good luck,
» Submitted by carey m - Tue, 7/16/19 » 4:36 PM
1/ can you email pictures ? to : [email protected]
2/ can a 150 # woman paddle this boat ? we're looking for one that both a $150# f and a 200# m can both use. 3/ did you car top it ?
