Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Hi, I am finishing off a Chesapeake 17 and wanted to paint the underside up to the waterline (mainly to cover the stitching holes and myfirst ever scarphing attempts!). What's the best way to mark a straight line at around waterline level? If I follow the panel joints, it won't be on the waterline from what i can see. No waterline is marked on the plans, but I may be able to draw one and measure down form the sheer at set points. Any other suggestions on how best to do this? Or should I just follow the panel chine joint line? Thanks, Melbourn, Australia
Darren
RE: Painting the waterline
Like fishbuster said try putting it in a pool. Put a couple of bags of sand, or even a couple of buckets of water to immitate some weight in the Kayak. Then use some short pieces of tape, placed vertically around the craft at the water line-Then mark the water line on the tape (or put the tape so the bottom marks the water line). Then connect the dots/tape marks for your water line.
» Submitted by Fishbuster - Wed, April 16 » 4:16 AM
If you put it in the water you will see the true waterline, taking the guesswork out of it.
