Annapolis Wherry Plank Alignment Question
Just started an Annapolis Wherry build and I've run into an issue with Plank 2 puzzle joint alignment from Stern side. The blueprint diagram indicated 1 1/16" deviation from the straight line mark on the Plank 2 Stern side joint. The natural arch would put the deviation at 1 and 15/16 inch. Am I reading the diagram correctly. Is the 1 1/16" notation at the stern side scarf? Is 1 1/16 correct? Thanks for any help. Bow side setup works fine with 2 15/16 inch in instructions.
RE: Annapolis Wherry Plank Alignment Question
The measuring-off-the-stringline business is for Annapolis Wherries with scarf joints.
You have puzzle joints, and no measuring is required at all---just snap the puzzle joints together and you'll have the correct alignment.
» Submitted by wendtru1 - Wed, 1/15/14 » 4:33 PM
Same issue with Plank 3 stern side as well The 1 1/4 inch is not workable without severe distortion of the joint. More like 2 inch is natural arch. What am i doing worng here?
