So, huge mistake on my KAHOLO. Large air buble up front on top, about the size of a quarter, sticks up quite a bit. What's the best way to fix? Cut out most of it, sand donw around ir, and patch with more glass?
Your suggestion would work. probably the "best" way to do it.
If it hasn't been too long you might be able to warm it up with a heat gun so the epoxy softens, then puncture the bubble, inject a bit of fresh epoxy and press down. Perhaps some plastic and a weight to keep it flat.
either way, once done, filled, sanded, varnished, no one but you will ever know it was there.
RE: large air bubble
» Submitted by EdBru, NY - Tue, 4/30/13 » 1:50 PM
