Model design/plans recommendation
Here are the criteria for the design I'm looking for:
1. It should be seaworthy in ocean conditions. It will need to be highly resistant to capsizing.
2. It should sail with only a small amount of heel.
3. Plans should be available and contain all pieces I would need to cut. A 3D model that allows me to scale up/down as needed and print out these pieces would be ideal.
4. Ideal length is about 4 feet long, but again, if there's a model, I could scale.
Here is some inspiration for something like what I am looking for:
http://www.youtube.com/watch?v=K_3v-...eature=related
Any suggestions? Thanks in advance!
RE: Model design/plans recommendation
Here's a grat place to start looking around, if you haven't already found it - The American Model Yachting Association.
http://www.theamya.org/index.php
» Submitted by hokeyhydro - Sun, 11/18/12 » 8:38 PM
I seem to recall Wooden Boat magazine had drawings and a build article for a 50" radio control sailboat. AGoogle around and you should be able to find lots of info since R/C sailboat racing is fairly active. In the `70s I manufactured fiberglass model kits for R/C racing. AMYA is another info source, that would be American Model Yacht Assoc.
