Great Auk 14
After a break for a month and a half I finally got the first strips on the deck of boat #3.
It's raining today so it's back to the boat cave to glue some more on.
34 replies:
RE: Great Auk 14
Looks great.  I'm considering a GA 14 after a Shearwater Sport H.  Do you have any more pics you could share?
Joe
RE: Great Auk 14
There are more here....
https://picasaweb.google.com/danielthaler/GreatAuk14#
(for some reason I still can't get the hyperlink thingie to work on my mac)
RE: Great Auk 14
Here's another. I'm still mulling over the deck pattern
RE: Great Auk 14
A few more sticks glued on...
I think I've figured it out
RE: Great Auk 14
Looking Great Dan.  Keep posting photos of your progress.  I am one of your biggest fans.
Lou
RE: Great Auk 14
Here's another...
There's a theme developing here..
1-I'm sick of bending and twisting strips
2- some sort of weird homage to Chris Craft
RE: Great Auk 14
Dan, I have built both the 14 and 17 Auk. I understand the statement " Sick of bending and twisting Strips." I notice very few staples are you using hot glue?
 Hagen
RE: Great Auk 14
No hot glue, but lots of plywood U clips
RE: Great Auk 14
Dan,
That looks pretty cool, and I will consider using it on my Night Heron deck, because I am sick of bending and twisting strips (I bent and twisted all of my hull strips with no cheaters)...lots of work!
Good work, and thanks for the pics,
 Chris F
RE: Great Auk 14
Here's another...
I put it in the slings so I could get a side view. I'm pretty much winging the deck pattern and some of the spacing is a little off, but I think the overall effect is ok
RE: Great Auk 14
Off the forms...
Now time to scrape and sand
RE: Great Auk 14
Cockpit cut...
 That's a big cockpit! I'll probably be adding knee braces
RE: Great Auk 14
I decided that the cockpit as above is too freaking huge so I decided to do a full recess and make the width smaller by an inch or so (still need to sketch it out). Here it is roughed in and the deck rough sanded...
RE: Great Auk 14
Looks GREAT Dan.
I have been kayaking every chance I get so I have not been working on the kayaks at all this summer.  But soon it will be time to build again.
Keep up the good work and thanks for posting photos.
Lou
RE: Great Auk 14
Underside of deck 'glassed
RE: Great Auk 14
All glass on and trimmed. Test fit and photo op.
RE: Great Auk 14
Looks Great Dan !!!
Is the light colored wood Alasaka yellow cedar ?
Lou
RE: Great Auk 14
Good question, Lou. It's whatever CLC supplied with the kit. Eastern white or Alaskan, not sure
RE: Great Auk 14
Hello to all of you.
I just picked up the plans for the Great Auk 14.  I'm an old time boat builder (40 years).   Hobby only.  Sail and Canoe only.  Dan, I went to your website with your pictures of the boat.  Very helpful.  In just looking at the plans (with minimal instruction), I wonder how you determine the placement of the cockpit?  Also, what width cedar strip did you folks find best to use.  On some of the pictures I have seen of this boat, the strips appear bigger than what I am use to when building a cedar strip canoe.
This is a link to some of the boats I've done in the past.  Right now, I am working on a 15 foot ranger with my youngest son (I have 4 sons and each one builds a boat with me when they reach 14), a 12 foot bullseye (nice cat rig sail boat) and a 17 foot trimaran.
Thanx for letting me join in your conversation.  I am sure I will have questions as I move along.
RE: Great Auk 14
Jeff,
The cockpit location is pretty much determined by the form shape and the dimensions in the plans. I found it to be quite huge and reduced it by about an inch and a half overall by doing a full recess.
The strips are 1/4 by 3/4 bead and cove as supplied with the kit.
RE: Great Auk 14
Time for much sanding, a little bit more glass, then glue the sucker together..
RE: Great Auk 14
Looks  Great Dan !!!  Nice lay out of colors.
Now that the kayak season is coming to an end, I plan to start building again soon.
The Petrel is about half done and I would like to start a Great Auk this winter.
Keep up the good work.
Lou
RE: Great Auk 14
All together now!
RE: Great Auk 14
Third coat of epoxy...
RE: Great Auk 14
Looking good, Dan! Gonna get it in the water before winter?
Is it an optical illusion, or is there no aft bulkhead?
Cheers, Pat
RE: Great Auk 14
No aft bulkhead yet, Pat. I have a foam one cut and ready to go in. Once the bottom is coated I could probably splash it. The water is still warm here.
RE: Great Auk 14
Couldn't do this with the longer boats....
End pour in the stairwell
RE: Great Auk 14
Varnished enough and rigging on....done!
RE: Great Auk 14
Very nice looking craft. How did you seal the slots for the deck rigging loops?
RE: Great Auk 14
Another great looking kayak Dan !!!  Very nice, great colors, well done.
Lou
RE: Great Auk 14
Beaker, I didn't. The flanges on the underside should keep out most of the water and there is no forward bulkhead anyway. All the instructions I've read call for silicone sealer, but I decided to skip it. I can always do it later if I get too wet. Lou, Thanks. Looks like I'll get to see if it floats on Saturday...
RE: Great Auk 14
It floats!
I think I will be sealing those loop slots and getting a neoprene spray skirt that fits. The cockpit is a bit larger than our Shearwaters and only my old nylon spray skirt fit and I did take on some water
RE: Great Auk 14
Dan,
Your smile says it all.
Have a great time with it.
Lou
