West 407 with MAS Resin and Hardener
Is it OK to use this with my MAS product?
5 replies:
RE: West 407 with MAS Resin and Hardener
Oh rats! I'll have to return it. I was hoping I could use the West 407 micro balloons with my MAS. My local West Marine does not keep MAS on the shelf.
To clarify: I'm using MAS resin and hardener. I want to know if I can use West 407 microballoon filler. It seems to me that it would be OK since that is just a filler/fairing compound, but I want to be sure.
You are good to go! You can mix the fillers all you want. You can't mix an epoxy resin from one manufacturer with the hardener from a different manufacturer, unless you have an advanced degree in chemical engineering.
That is what I was hoping to hear. It made sense to me, but I had to verify. Thanks!
» Submitted by ` - Wed, 5/19/10 » 4:44 PM
Jeff,
Your can use West System (105+407) over your already cured MAS epoxy but you absolutely can not mix the two brands. They have different chemical formulations and different mixing ratios.
