Re: Mill Creek 16.5
Posted by Brian Carlsen on Oct 10, 2007
Tom, Go for it. You don't need skill, just some patience when it comes to sanding. Because epoxy takes so long to dry its hard to make a mistake due to rushing. Plus just about any mistake you make has been made by someone else so there is a fix. You've now seen the amount of people who have responded to your post, you'll get the same response whenever you need advice. Or you can pick up the phone and call the folks at CLC for a quick answer. Brian
In Response to: Mill Creek 16.5 by Tom P on Oct 8, 2007
