Ches. 17. How much Epoxy?
Posted by Kyle Lindstrom on Sep 21, 2007
Here is the story. I'm building the Cape Charles 17. Back in the day when this was designed it called for only fiberglass tape on the interior and exterior of the seams. Now I'm adding improvements that were learned over the years. The Chesapeake 17 replaced the CC 17 and now you use tape on the internal seams, glass cloth in the cockpit and cloth on the exterior of the hull, which is what I plan to do. My CC called for 3 qts of epoxy. How much epoxy is required for the Chesapeake 17? I have a feeling I'm going to need an extra quart of epoxy because of the glass. Thanks
Kyle
- Re: Ches. 17. How much Ep by Larry Roberts on Sep 21, 2007
Re: Ches. 17. How much Ep by Kyle Lindstrom on Sep 21, 2007
- Re: Ches. 17. How much Ep by Doug W. on Sep 24, 2007
- Re: Ches. 17. How much Ep by Kyle Lindstrom on Sep 24, 2007
- Re: Ches. 17. How much Ep by Jim E on Sep 24, 2007
- Re: Ches. 17. How much Ep by Doug W. on Sep 27, 2007
